Hi All,
I have got ZM setup and it works great on port 80 but i am wanting it on a different port, i have set up apache to listen to port 81 as well , from this i can load the ZM console but when ever i load a live feed it does not work on port 81 but does on port 80.
on port 81 it opens the new window but only shows a image place holder, as though it can not access the feed,
does anybody have any ideas?
many thanks
ZM Port Numbers
Re: ZM Port Numbers
Maybe you missed something, this is what I did to use another port in apache (taken from somewhere in this forum):
1- edit /etc/apache2/ports.conf, then change both "NameVirtualHost *:80" and "Listen 80" to the new port
2- edit /etc/apache2/sites-enabled/000-default and change "<VirtualHost *:80>" to reflect the new port
3- restart apache "service apache2 restart"
Hope it helps,
PacoLM
Hope it helps,
PacoLM
Re: ZM Port Numbers
If you want to check that Apache is now listening to port 81, try http://127.0.0.1:81 in your browser and you should get the Apache default page.
John
Re: ZM Port Numbers
It could be interesting my experience.
On my server I have Zoneminder and a website.
My need:
1. the website on port 80, then redirected to 443,
2. Zoneminder on a different port: port 81. (i.e.: Zoneminder reached directly on localhost: 81, not on localhost:80/zm)
Solution:
1. comment in sudo nano /etc/apache2/conf-available/zoneminder.conf the line:
#Alias /zm /usr/share/zoneminder/www
2. create a virtual host file:
Listen 81
<VirtualHost *:81>
ServerName mysite
DocumentRoot /usr/share/zoneminder/www
</VirtualHost>
<VirtualHost *:80>
ServerName mysite
DocumentRoot /var/www/html
Redirect permanent / https://www.mysite.com/
</VirtualHost>
then I'm able to expose my website on Internet on 443 (portforwarding 443 port on router) and expose Zoneminder on Internet on a dedicated crypted port, i.e. 2443 (reverse proxy between 81 and a dedicated crypted port and portforwarding of the dedicated crypted port on router):
<VirtualHost *:443>
ServerName mysite
SSLEngine On
</VirtualHost>
Listen 2443
<VirtualHost *:2443>
ServerName mysite
SSLEngine On
ProxyPreserveHost On
ProxyPass / http://localhost:81/
ProxyPassReverse / http://localhost:81/
</VirtualHost>
My need:
Solution:
Listen 81
<VirtualHost *:81>
ServerName mysite
</VirtualHost>
<VirtualHost *:80>
ServerName mysite
</VirtualHost>
<VirtualHost *:443>
ServerName mysite
SSLEngine On
</VirtualHost>
Listen 2443
ServerName mysite
SSLEngine On
</VirtualHost>
Users browsing this forum: No registered users and 6 guests
